Noob Q: How to reduce body roll on a budget?
I have Koni Sport (red) adjustable shocks and King super lows fitted, with 205/40/17s, and I'm wondering if there is anything I can do with the above setup to reduce body roll. The konis have 3 adjustment settings, and is currently set on the middle one. Would it help if I set it at the highest (stiffest) setting and fit some bump stops (I don't think I have any)?
Basically I have a bit of a scrubbing issue, and just got the car back from trying to sort it out. I've had the front guards rolled, and the plastic tucked and some metal tapped to reduce the scrubbing. It is better, but I still scrub when doing a hard turn and hit a bump midway, or if I'm going over a steepish driveway at a sharp angle. So I thought if I could reduce the body roll on the current set-up I could get away with it.
I suppose the other alternative would be to fit stiffer springs, or raise the car by 10mm, but I don't have a lot of budget to spend on it ATM...
Any thought/suggestions?
Cheers.
