just watch youtube seen a lot of vtec clip .. just wondering whether the vtec on a jazz can loud??
Well its a SOHC VTEC so probably not as loud as the DOHC VTEC(I presume) on the video clip. Only way to get it louder is with a high flow pod + CAI for a little performance gain.
A guaranteed way is to have a CAI (plus pod or cone filter) and...... aggressive cams. For your SOHC VTEC, then you will have no low end, but it will scream up top.
My B18B screams with no vtac.
mine farts jkz! but seriously it roars but not as much as a dohc
dohc roars
sohc purrs :D
u won hear it for a jazz.. u may..just barely.
its not as or nowhere as close as distinct comparing to B and K series when it kicks in. u probably wouldnt know even if it has engaged as it kicks in b4 3000rpm.
it engages at around 2300 rpm but u can't hear till > 3000rpm
does the changeover when the vtec kicking noticeable???
Quote:
Originally Posted by SiReal
I 2nd that..Quote:
Originally Posted by asiansquad
Pretty much no scream with stock jazz. Every car roars a bit when you rev... so just because the car has a bit more noise doesn't mean it is screaming like the DOHC vtec
Mine yelps. But thats cos its stock.
>_<
