Offset
I want to know what the stock offset is for a 91 integra (with the OEM 14s), and also what the limits of offset would be with some aftermarket wheels, ie. how far could I go before I have issues? I'm currently on a set of EuroHart S-Line 17 inch wheels (which I don't know the offset of either), so could someone please tell me what sort of offset I could have with either 16s or 17s?
This is all with aftermarket suspension as well (Koni), but nowhere near slammed. I want to get some new wheels but choosing the right offset (as well as finding 4-stud wheels that I like) is proving to be a pain!
Hope someone can shed some light on this.
Thanks in advance :)
I am moving this - you might get a better response in the integra forum.
Might be worth a search over at Honda-tech if you dont get a response :).
Hey mate, according to this site, it says ur stock offset is +45.
Regardless, take your current wheel off, have a look inside and you should see a 2 digit number. e.g. 45. That means the offset is +45. If you take into consideration the width of the wheel and if that width is fine (i.e. no rubbing, etc), then you can be safe to assume that a same width wheel, with same offset and difference diameter (16 or 17) should also be fine to run on your car provided its not ridiculous like 18s or 19s.
Also, tell us the width you are expecting to run (i.e. 6.5", 7") and we'll tell you to the best of our knowledge the corresponding offset.
