how do i correct this...
When you login, tick the "Remember Me" box. But your browser has to allow cookie in order for this to work.
have sure you have your cookies setting properly configured
i dont recall every having to do this ever before.. but how should the settings be configured and where?Quote:
Originally Posted by Stoosh
what browser do you use?
For IE6, go to Tools - Internet Options... menu, click the Privacy tab, then set the settings to Medium. Other option is to click the Sites... button, then enter www.ozhonda.com, and click Allow button.
For Mozilla Firefox browser, go to Tools - Options... menu, click the Privacy icon, select the Cookies tab, and tick the "Allow sites to set Cookies", and set to Keep Cookies until they expire from the drop down list.
I can't help with other browsers since I only have IE6 and firefox.
HTH.
ta for the advice.. it usualli never happens.. and im using IE6.. also it happens on other sites/forums also... this isnt normal I gather.. cbf formatting again...
what might help is to clear all your cookies first. There should be a Delete Cookies button in the Internet Options, the first tab (can't be bothered to check what it's called, probably General)
yeah ive done this already too
there is a problem with this forum software that sometimes makes you unable to login if you are using a custom skin, scroll down to the bottom left and choose
vB-Default skin and see if that works
if it happens with other forums also.. could it be the same problem too?
If it happens with other forums and wasnt happenin b4, more than likely its some settings that have changed on ur browser - not to do with the site/s.
If it was the sites fault, then im sure more ppl would be posting up about this sorta issue.
Jst try doin wat euro77 has listed, should do the trick.
i think ive done the lot.. and it aint workin for me :(
