thermostat changed...now needle sits?
just a quick one, do i need to remove the coolant drain bolt when changing the radiator coolant cause i'm going to change my thermostat. oh and any other tips to help out would be good as well.
thanks
Thanks guys for your help, everything is done, now all i need to know is where abouts the needle in a vtir sits.
My needle sits covering the little squiggle on the temp symbol and doesn't move much above or below is that the correct spot? so far i've only driven the car once for about 20mins during the day.
