[euro] Window Switch
Has any body else noticed that the power window master switch on the drivers arm rest does not illuminate at night with the rest of the switches. Is this normal or does mine have a blown bulb. The manual does say that these switches in general should light up when your headlights are turned on but does not relate specifically to this switch. Thanks guys
Which switch? The driver's control panel front right window switch? Or all 4 window switches on the driver's control panel?
Its the master power window switch on the drivers armrest which can deactivate all the other power windows.
Ah, you mean the button that disables the other 3 windows? Mine doesn't light up.
Tks aaronng, solved that problem!
The single button with the picture of a window and an 'X'... mine doesn't either, MY06.
