I have noticed recently that my spare wheel well in my boot is holding water but I can't see any holes or where it would be comming from. Any Ideas?
Should be coming from the boot, or from the seals.
I had the same problem with my EF7.
Spray water over the top of the boot, and on the inside pull your seats down and check if it is dripping down from anywhere.
I found that mine holds water too - in my eg hatch...
I found under the wheel there is a little hole - which was filled with dirt... unblocked it... and the water ran out :)
What car is this in i had the same problem.
Try searching for ek with leaky boot I posted pictures of where it was coming from.
found it i found these were leaking when i put a hose upto my rear bar. so I just coverd this white plug with sicaflex. there is one on your l/h and r/h saide. Als o if you haev a eleectra antenna mine was leaking from there also. I did the same thing.
http://img133.imageshack.us/img133/3983/dsc011925pu.jpg
ive had the same problem with my ED, i did think it was the lights but it could be a hole thats filled with dirt aswell...
So it seems the mighty hondas have a Problem...LOL!
check tailights mate, often the gasket shrinks with age and allows water to seep through.
had the same problem with my CRX aswell.
agree with kayot1k.
might be ur boot seals are fudged...
