idle problem
hey all:
My car has been acting weird recently, it happened so sudden, before when do a cold start the idle will start at 1500rpm, then gradually drops to 1100rpm when it is all warmed up, now it starts from 1500rpm, then gardually raise to 2000rpm then suddenly drop down to 1500rpm then gradually drop down to 1100rpm,everything is normal again, today, after half an hour drive , i turned off the car ,then turned back on, normally should stays at 1100rpm, but today it raised to 1500rpm, anyone else had this similar problem ,cheers
same thing happened to my civic.
* Clean the Throttle Body. http://www.ozhonda.com/forum/showthr...highlight=IACV
* Clean the IACV filter. http://www.ozhonda.com/forum/showthr...highlight=IACV
If the engine is a D Series:
* As above, and Screw in the FITV valve. http://www.emotors.ca/Articles/97.aspx
