98 DC2 VTI-R Rear Subframe crack
Hi all,
This happened a while ago but I forgot to post about it.
I have a '98 VTI-R Integra. It is stock except for upgraded suspension (shocks, springs, camber kits, rear strut brace and upgraded rear swaybar - Whiteline 23mm).
Basically I heard a clunking noise after a reasonable boot through the twisties and upon closer inspection the mounting point where the rear swaybar bolts on had actually cracked! :eek:
It has been fixed. Took it to a specialist suspension repair place and they not only welded the cracked section back together, but also strengthened it further by making up some brackets and welding them in. The guy who fixed it said that it will now be OK with the thicker swaybar and shouldn't cause me any more issues. Cost $550 which, all things considered is not a bad price to pay. Just wanted to warn anyone thinking of doing similar mods that it may be best to spend the $$ up front and have the rear section strengthened if fitting a heavy duty swaybar (the standard one is 18mm if I'm not mistaken, so 5mm increase is pretty big!)
