weird movement
http://www.youtube.com/watch?v=ReC1zUGSsX4
weird movement
In the old days, I would have thought axle tramp
Damper setting was probably for a JGTC track, but not properly adjusted for Tsukuba.
weird handling there:S
Spoon might have to re-adjust rear damper to suit with tsukaba but in didnt happen with Spoon FD street version as you can see from the link below. It look very stable for Street version.
http://www.youtube.com/watch?v=Hit17uZP6pc :thumbsup:
if you were runnong 20/18 KG/mm springs YOU'd be bouncing allover the place too if you were driving that hard ;)
hahahaha.. well the standard issue springs on spoon full-spec coilovers are 20kg/mm front and 18kg/mm rears.. your stock springs are ~3-5kg/mm... that's VERY hard.
thanks Ichisima-san says "Hi" hahaha.. got more than a photo when i was there ;)
