DIY: FITV removal, clean, adjustment B16a
Aim:
The Fast Idle Thermo Valve (FITV), is a vale under the throttle body in the older B series engines (b16a1 and the b18 in the da teg). Its purpose is to allow more air into the engine when it is cold.
I was having problems with my idle remaining stable when starting from cold.. so i thought i would check out the FITV to see if it was in fine working order on my b16a EF8 Crx.
Tools and parts:
Pliers
Screw driver
Socket set
Patience!
Radiator Fluid
Steps:
*I FOUND THIS TO BE A REAL FIDDLE AND F-ING ANNOYING JOB! No room to get to the hose clamps, hose stuck onto pipes.. etc etc.. Only do this if you really need to.. or else it will cause possible hours of pain.
1) Firstly remove your intake pipe.
2) Look at the throttle body. Directly under it is the FITV. There is 3 bolts holding it on (shown in green). And two radiator hoses (in blue).
http://i13.tinypic.com/2d6v4es.jpg
3) So undo the 3 Bolts to remove it off the throttle body.. Some say they can open up the FITV with the hoses still connected.. i dont know how that would be possible with the room..
4) Now remove the hoses connected to it.. you will lose a bit of rad coolant, but nothing major.
5) You should then have the FITV out. (as you can see, i got pleasure from hacking one of the hoses)
http://i5.tinypic.com/34quvkp.jpg
and the other side:
http://i7.tinypic.com/2mwv5m9.jpg
6) Now you can remove the end cap but undoing the two bolts.. This will allow you access to the mystical innards!
http://i5.tinypic.com/2wc1ykm.jpg
7) Now you can access the valve. From the information i have read, you need to do the valve up tight by rotating it with a screwdriver in the notchs it has (one is shown in pink). You just get a flathead screwdriver and tighten up the valve in the housing (note the green threads one on the valve and one in the housing). Mine however was already tight, but others have had theirs unwind. So basically to adjust it just do it up tight.. I removed mine also to simply check it.
http://i13.tinypic.com/2i27jgl.jpg
8) Now put it all back together and top up your radiator fluid (you may need to undo air bleed valve.. in other words, do it the proper way).
Additional information:
Basically, i doubt it made a difference to my idle... I believe a simple ECU reset should fix my erratic idle during warm up.. but it is good to check out maintenance points such as these anyway... Was a friggen bitch to do though due to limited space.
You may also want to clean the ports on the throttle body to the FITV when it is off too!
