im looking to build a head that will support my b16a2 that will be boosted looking to make good mid range power?
Most turbo engines aren't designed for mid range...........
Generally speaking,
Low-Mid= Blower
Top end= Turbo
No,
You can have a low end range with the correctly chosen turbo (of course its never going to be instant) as it is the same with mid-end etc. It all depends on what the car is going to be used for.
atm turbo kit isnt on....
got a mircotech with a tdo5
dont know about cams wat to go for...dont know size of injectors...was hoping someone with a b16a turbo will reply
wat power r u aiming for???...HKS gtrs r great turbos to run....not laggy and make good power..
hoping to pull something between 150 - 180kws at the wheels
i wanna pull a 12 down the 1/4 mile... but every day use
Good luck on your 12 sec pass it's not as easy as you think. Anyways if you're building a b16 for turbo it's not really the head you have to conentrate on. Bottom end is where it's at for boost.
Like fishman said, it's not really the head that you are looking at when boosting. Sure, ported polished etc will always make you extra power, but it's really money you don't need to spend.
The best set of cams you can buy for a B16A with boost is ITR cams (I actually have set from when I was going to boost my B16 - PM me if you're interested). I did extensive research and even spoke to some US guys to find this out and 8/10 of them all said the same thing - ITR cams.
didnt think a 12sec pass would be easy in a honda.....
but still hoping to rip out a 12sec pass after the turbo kit is on
where do i start with the bottom end?
decomp?
bore?
shit theres heaps of things to do
