Can anyone point me in the direction of where I can get an RPM signal from my engine (D16A3) to run a AFC? I've done the standard searching but no one seems to have info on this model.
Is your car the 87 model OBD0 Teg ?
If this is so...
Your ECU does not have rpm output.
Use the blue wire from the dissy for tacho in dash.
Or an injector earth can also be used.
Pins A1, A3, A5, A7 are injector drivers. (White plug)
To use an injector as rpm, set AFC to 1 cyl in settings.
