Rear Brake Pad Change on EG
Aim:
To change the rear pads
Required:
jack
stands
12mm single hex socket
10mm socket
rachet (to suit the sockets obvisouly)
flat head big screw driver
rear pads
Step 1:
jack the car up
http://img221.imageshack.us/img221/2456/01ke0.jpg
Step 2:
support on stands, on each side.
http://img221.imageshack.us/img221/4883/02zj1.jpg
Step 3:
take off the cover via the 2 10mm bolts
http://img221.imageshack.us/img221/7321/03bb7.jpg
http://img246.imageshack.us/img246/9299/04rz6.jpg
Step 4:
undo the bolts on the caliper using the 12mm single hex socket, you use the single hex socket, to prevent rounding of the bolt. you should impact to loosen the bolts, so you hit the ratchet with the your palm, to crack it first, it helps not rounding the bolt. then slide off the caliper, and place it somewhere where it doesn't put stress on the lines
http://img187.imageshack.us/img187/3885/05pw7.jpg
Step 5: take out the pads, and take off the shims off the old pads, which should come off easily, and put it on the new pad, put the pads back on the way you took it off. if you got genuine Honda pads, it would come with shims and grease, put the grease between the shims and the pads, and where the calipers and pads meet.
Step 6: screw the piston back in with the big screwdriver, it goes clockwise to go in, while doing this, make sure your brake fluid doesn't flood out of your reservoir, so if it's full, take some out, via a syhpon or whatever you want to use. lol
http://img187.imageshack.us/img187/6503/06jl6.jpg
step 7: slide the caliper back on.
step 8: do everything in reverse order, repeat for the other side.
Other comments
and er.. your done.
Other comments:
this guide is quite universal i guess.
