can u get 4g input and 4g output distribution blocks? coz i need to run an audison srx2s amp and monoblock sub(400rms). and i have been told that its better to run 4g for the sub particularly at that power level.
Yes there is, did you want fused? or non fused?
Look at stinger gear for good quality distribution blocks.
However you can still run 8gauge outs to your amps, if your running 500w+ then its a good idea for 4 gauge into your amps, but 8 is suffcient enough.
Stinger has a 4awg "t" block.
http://www.advanceae.com.au/catalog/...oducts_id=2911
You'd be able to find it at a a JB Hifi Store or most car audio specialist.
whats the difference between the one in the above link and this one? other than the 4 4g outputs
http://cgi.ebay.com/Stinger-HPM-4-Ga...em170121694974
does it have something to do with midi fuse?
The one I posted basically has a single 4awg input and splits it so that you can connect UP TO 2 amps and is UNFUSED.
The one in the ebay link has a 0awg input as well as two 4awg inputs and splits it into for 4awg, allowing a connection of UP TO 4 amps. It's also fused which gives some protection to the amp (if the correct fuse is used).
i recommend u get a fused one. get it from jaycar
Contact Marty at FHRX in Sydney, he has genuine Audison power distribution.
Yes we keep most Stinger and Audison Connection terminals here...
