i'm going to reset my srs , went under dash , only found one yellow two line plug, it has two yellow wires , it is located right top corner of fuse box , is it the one ?
Check this link http://www.ozhonda.com/forum/showthr...ghlight=SRS%2A
Basically don't worry about the colour of the wires. The way to check is when you pull the plug out does the empty socket on the board have pins? If not then that's your srs wires, as the srs wires are only service modules hence it doesn't connect to anything.
thanks guys,doesn;t matter anymore, i figured out the the problem already , cheers
