im buying a honda accord 2moro n need 2 noe some main problems with the accord its a 97 model
thrash it.. push it to the limit..
the engine should roar..
take it round a few sharp corners..
let go steering wheel see if it pulls
brake hard and see if the car pulls to 1 side??
listen for engine noise
gearbox noise
smooth gear changes
electrical..
windows..
should be fine
also check the weldings of the car.. see if both sides have same welding marks..
and knock all panels.. if one sounds hard and low knock noise.
cause has been puttied or repaired
:D
Ken
If the car has been regularly maintained and serviced ie every 10k (at least) it will be good for up to 400 000kms.
