Brembo Q?
Fitment of JDM ITR Brembo on EP3R?
I have probably answered my own Q here, but here it is. I just need to clarify with those who have done it?
My question is does sound quite silly but here it is.
AUSDM ITR change their LCA/HUBS to fit JDM BREMBO'S yeah?
So in theory, since EP3R's have the same sussy as the JDM ITR they (JDM BREMBO'S) should be a straight fit.
Constructive replies pls :)
Thanks in advance
No, they are not a straight swap.
You can try customizing brackets but I can tell you it's not going to be cheap/easy and who knows how reliable they are. You will also need new rotors.
The offset for the DC5 is also very high, +60 from memory if I am not mistaken. Your standard wheels will not fit as well, you will need aftermarket wheels for this offset. Or you can try to run a 15mm spacer on standard wheels (+45 offset), which isn't really recommended.
What's wrong with the type R caliper? It is more than sufficient for track. Just change pads and rotors with some stainless steel brake hoses and they are ready.
Too bad :( mate has a set, I could get it cheap thats all.
