Hi Guys,
I have a Walbro 255 intank pump left over from my turbo days. I was wondering if it is of any use in regards to Hondas upgrading to this or should I just sell it??
Hi Guys,
No upgrade/advantage from putting this in.Stock pump is fine.I replaced my stock pump with one these although the 190lph would have been suffice.I only did this because my stock pump was 11 yrs old so I thought why not replace it.
Someone correct me if I'm wrong :)
Well, if you're going to run higher pressures, its actually better to run a high flow pump.
That's good to hear cause I've got a FPR and I'm running it at 42psi.Stock is 36psi.
