Power
Memory (+12v Constant) Blue/White
Ignition (+12v Switched) Yellow/Red
Ground (-) Black
Illumination Red/Black
Power Antenna Yellow/White
Speakers
Right Front (+) Red/Green
Right Front (-) Brown/Black
Left Front (+) Blue/Green
Left Front (-) Gray/Black
Right Rear (+) Red/Yellow
Right Rear (-) Brown/White
Left Rear (+) Blue/Yellow
Left Rear (-) Gray/White
wynode edit: Just added some formatting
Damn..
if only i'd found this site 8 hours earlier!
as i was installing a H/U for a prelude!
(was a pain trying to find which speaker wires are for what)
can you make it a sticky. i know there aren't many threads here. but when it gets cluttered it will be best to be a sticky.
thanks
www.installdr.com
useful wen installing head units for those who are interested :)
is the wiring standard for all hondas ?
specifically my 2000 EK sedan ? :)
I found that the codes are not entirely correct ?
Need to modify/update to latest or categorise for different models ?
Caused alot of headache on monday when i installed my HU :(
from memory i think the colour codes are slightly diff in my old skool akord.
Just a bit of a bump to answer a few questions.
From my HU:
* "motor antenna control lead" - Same as power antenna?
* "External amplifier control power lead" - Is this the "remote wire" for the amp?
From the car:
*Illumination (red/black) -...? - there doesnt seem to be a matching wire coming from the hu.
What car do you have ?
Not all cars have the same wires.
Im not sure if that statement applies to HU's as well.
5th gen accord.
I'm looking at it right now.. i might be able to figure it out.
Wiring loom, 1994 Accord.
Power
- 12V Constant - White, with yellow. Silver circles
Acc/ign (12V switched) - White with red
Ground - Black
Illumination - Red with black
Power antenna - Yellow with white
Speaker
Front Right -
- Blue with green
grey with black
Front Left -
- Red with green
brown with black
Rear Right -
- Blue with yellow
grey with white
Rear Left -
- Brown with white
Red with yellow
Disclaimer - I can verify that the stated wires were exact in my car and my wiring loom. I cannot ensure that different cars will follow similar wiring and due to the fact that myeslf, here and installdr have vastly different loom codes them you can assume yours to be different.
Doing this is quite simple, you can easily identify the speaker wires because they are coupled together. To identify the speaker, simply connect each end to a AA batery the speaker will crackle and the low voltage shouldnt harm the speakers. The power wires can then be identified by using a test light, ground one wire and then connect the other wire to each of the 5 remaining loom wires. Doing this when the car is turned off will identify the constant power, and then turn the ignition on and use the light to identify the acc/ign power wire. Remember that if you touch the 2 wires together you will likely blow a fuse.
