Replacing D15B7 --> for a D16Y4
Long story short, my D15B7 needs replacing because its a fairly old motor, and i found a good bargain on a D16Y4 that comes with gearbox, block, head, pretty much the entire engine.
Problem is, My D15B7 is OBD1 and the new engine is OBD2.
I kno paul (honda_b_blasting) had written up a small thread in the past regarding the conversion, but i still want to clear things up a little bit.
Questions
1. i will be using my OBD1 loom, so does that mean i will be using my injectors, plugs, fuel rail and the wiring from my D15B7 motor on my D16Y4?
2. I have examined the dizzy on the D16Y4, and the plug is definately different and will not connect to the plug on my OBD1 loom. Can i use my D15B7 dizzy on my D16Y4 head? or is there another way to resolve this
3. The D16Y4 has an alternator with a different plug and will not plug into my OBD1 loom, can i swap this alternator for my D15B7 alternator to resolve this problem? or is there another way this can be done so that the plugs will fit
4. Will a D16Y1 rocker cover fit on my D16Y4 head?
needing the Ozhonda community's help again :thumbsup:
