whats the cost to convert auto to a manual? or would it be cheaper to just get the car thats already manual?
definately cheaper to just buy the car in manual..
You will need a trans/shift linkage/cluster/clutch pedal. Not sure if theres also wiring you will need to work with.
Not to mention the amount of man hours involved. The labour would be very expensive.
hey dude.. what engine do you have?
best thing is, issit really worth it investing cash onto that engine? for a transmission change... i would actually just suggest to do a complete engine conversion.. might be abit more.. but not a big gap.. if your refering to your GLI.. do an engien conversion to b16/18c
well i was thinking of either selling the car and get a manual one. was thinking of doing a b16 still not sure what the big gap $$ to do it on a auto. was looking towards a half cut.
u get an engine conversion.. assuming its manuall..
it should have everything.. will need shift linkage and ECU and few bits and pieces.. but if u get a half cut.. u will be set ;D GL with decision! if u got cash go for the k series :D
you much better off selling your car esp auto gli should be easy enough to sell to someone who has to have an auto car and likes to have efi as well.
your user name says it all lazyme. Try using the search button this has been covered so many times.
EXPO2ED has a good point. It will more than likely cost as much as an engine swap inc. a man conversion so you would be better upgrading the engine at the same time if you were to do this.
well i see how it goes through the yea but i more than likely looking towards the ek vti-r and getting the hang of man, thanks alot
http://www.ozhonda.com/forum/showthread.php?t=73513
took me only 1 minute
