Problems installing System into EG Civic Hatch
So mate and I spent all day (literally) removing my system from my old car (DC2) and putting it into EG. Previous DC2 install was done professional, but I felt like learning a thing or two.
Two quick questions!!
1. Wheres the BEST place to ground in the boot? Our Amp ground cable was only small, so tomorrow we're going to go into Northfield and buy a bigger one (bigger circle on the end). I was thinking grounding it against the rear seat belt locks under rear seat after filling it back? For testing we found it very hard to find a decent ground.
2. How do you run decent cabling for the splits at the front? Either we reuse the existing cable (for $700 DA speakers??) into the Split Box then into the splits and tweeters? Wouldn't it be better to run it better cable directly from amp, through doors into Split box? But if so, how the hell do you run the bigger guage speaker cables through the door? It looks like an impossible tasks without completely dismantling everything?
Without finding a way to easily run the speaker cable through the doors, we'll bring the amp back into the dash harness and reuse the existing small speaker cables? Is this bad for for SQ/SPL/Decent sound on expensive speakers?
Everything else, HU, running cables, powers etc was fine.
Thanks,
Matt
PPS for couple things that we learn't the hard way today. :cool:
Grounds = Important
Alpine 9831 doesn't send sound out wires when RCA's are in.
