parker lights out... front and rear including number plate... but dash light still working check all fuses and is ok
ooo wire is loose somewhere... u might need to get derty and follow every wire lol
checked all globes and are working so unsure....
alarm is connected to parker lights so when i press lock all lights works... so its either switch... or wiring... NEED HELP
DONE !!! Spent 2 whole hours chasing back wires in a shed on a 38degrees day... loose connection when alarm was fitted
lol u solved the problem by yourself :) congrats!
worth the effort in the 38* heat?? im sure u will be pleased with yourself.. give yourself a pat on the head!
need help again... tail light fuse in the kick pannel shorts out... any ideas? thanks
seem like i just fixed it again... found fog lights connected to the parkers are touching positive and negative... =) soo happy i found the source but now lights does not flash when i press lock and unlock...
going to take my car out to tonkins to check the alarm coz i remove the kick pannel. tonkins have lifetime warranty on viper alarms anyways
