Fuses?
Just a quick, got to work this morning and my tail lights (when my lights are on) and my parkers dont seem to be working..
its probably a fuse but i haven't had chance to check, anyone quickly tell me where it is (engine bay or intside, its probably on the insude) and what fuse so i can save time, ill be comming home in the dark and wont have time to look for it...be a huge help
Cheers
ey man, i am pretty sure it is located inside, under the steering wheel to the right
check the engin bay one 1st, it will say on the cover interior or exterior lightr. as most of the fuses are there. the inside ones are a bitch to get to if your in teh dark.
yea i kno, they are a huge pain, im a bit worried tho coz i went to start it jsut before and it didn't turn on, no ignition or nething, i hopped out of the car and the arial went up and down for some reason..then jumped back into the car and started it and it started fine...really weird - old cars and electrical issues are a pain
Fuse box is on the right hand side of the steering wheel
the interior fuse is a 15 i think.
look for a spare one most fuse boxes have one. the cover is labelled anyhow with wat fuse belongs to wat.
just read it and locate the burnt fuse.
The fuse box is behind the bonnet lever, it has a diagram on the box indicating which fuse is used for which electrical components, if it's not in there, then it's the one in the engine bay next to the brake fluid cylinder.
found it guys, it was a 10amp and all is good, thanks for the replies
Speaking about fuses, does the boot light & interior light use the same fuse?
