EK9 cluster needle jumping?
Just yesterday, I noticed that my needle on the speedometer was jumping all over the place, and I started playing around with in (in terms of speed) to see when it does it and at what position of the throttle, the needle ascends smoothly upto 60km/h no matter what the throttle position is on, after that, it starts spiking jumping back and forth. On normal throttle 1/4, it fluctuates 20kmhs or so, when WOT after 60, it fluctates alot, jumping upto 150km/h and back and so forth, once I do let off the throttle it calms down slowly with smaller jumps until it descends to the correct speed. Ive checked the wiring behind the cluster, and Im about to look at the speed sensor, someone confirm that this is what I should be looking at ( see picture attatched) , other than that, looking for some advice thanks.
PS: Or would I be looking at the actual internal workings of the cluster that might be making the needle jump, but since its all electrically operated, I should be just a signal that is been stuffed up?
http://img186.imageshack.us/img186/3...2008440om3.jpg
