Hey guys, Im planning to put on some wheel spacers on my jdm dc2r to make it have a better stance, Just wondering has anyone got these on their car and does it affect the handling of the car? or is there any downside of these at all?
Cheers guys
Cheers guys
downside =
dangerous
illegal
Sums it up. Dont do it. Get new rims.
Yeah I use them on some of my cars (non-honda's) they are not ideal. Dont go over 10mm without changing your studs or using these...
http://img.alibaba.com/photo/11247287/Wheel_Spacer.jpg
Just get new wheels.
10MM!! Don't go over MAXIMUM 3 mm.
Just get new rims man!
why does everyone think spacers are the devil.
a hubcentric 5mm spacer is 99% safe to use.
Racecars use up to 20mm spacers ffs.
Just make sure the spacers you use are not a universal crappy one that moves all around your hub. If you can get your hands on a spacer that has less than 3-5mm movement you should be alright (Either JDM spacer or custom made).
If you dont get ones that fit snuggly around your studs than you may have problems with steering wheel vibrations etc.
People may say that because you are extending the hub you have less thread for the wheel nuts to grab onto. Allowing a greater sheering force, but there is no way that by daily driving or even the occasional track day will a stud shear off with a hubcentric 5mm spacer.
and btw unless your trying to fit some new brakes or something along those lines under your stock wheels than i probably would put a hold on the spacers cause you probably wouldnt feel that much of a difference.
So in the end yes wheels with a wider offset would be better to buy if you want better handling (even forged wheels for better steering response). But spacers are not as dangerous as everyone percieves them to be (AS LONG as you dont get shitty ones)
Yeah thats what i thought, I know alot of people that do drifting that use spacers.. they dont seem to have problems
Race cars also use extended wheel studs. If not one other massive hub bolts which are better than 5 little wheel nuts.
Yes but there is a big difference between a 5mm spacer to a 20mm spacer!
A 5mm spacer still leaves plenty of stud track for the wheel nuts.
If you had to go any bigger than 5mm then i would probably invest in ARP extended wheel studs.
Ricki_Kalsi - what makes you think having a 5mm spacer is so dangerous.... do you actually have any experience??
Having a 5mm will leave a lot less thread for the nuts to hang onto using factory studs...
Get new wheels with a different offset and while you're at it get extended wheel studs and open ended nuts...
Doing so or using a spacer will change your turning circle and cornering ability of your car
NEVER EVER compare a race car to a production street car -_-
Next person that says "oh but race cars do it so it must be safe" will get a beating :thumbdwn:
At the end of the day
THEY ARE ILLEGAL
Ill agree that they are illegal, BUT anyone that is running an open air filter or exhaust is illegal as well so dont bring that crap into it.
A 5mm spacer will NOT leave a LOT less thread for wheel nuts. It take a way a little but no where near to put enough pressure on the wheel studs to shear off. And if you have the wheel nuts tensioned up how the hell are they supposed to get loose?
And BTW all you have to do is go down to QR to see how many ppl ARE actually using small spacers safely. They are racecars but they are also street driven. And for them to do hard track using stiff suspension, semis all day without have wheel nuts falling off or studs shearing off than id say its pretty safe to use on the road
CONSIDERING
- They are hubcentric
- They are no more than 5mm
- Wheel Nuts have been tensioned correctly
