Problem with Alpine CD Changer
Hi all, I have a Alpine 6 disc CD Changer added to my stock CD5 stereo. The problem is the left side speakers have no bass at all. The right side speakers work fine that is why I could tell the difference between the left and right sides. And this problem occurs only when I play CDs. The speakers on both side work perfectly fine when I listen to radio. This brings the problem down to the Alpine CD Changer unit. I suspect some wirings or connectors might have loosen. While the CD changer located at the boot is fairly easy enough to remove for inspection, the headunit in the car is a bit of a problem. How do I remove the headunit? For this case which part of the system such as wirings etc should I check apart from those connecting the Alpine CD changer with the headunit?
Any suggestions welcome. Thanks
