can it be done? thanks for the help.
can be possible, but y not go for the DC2R 5 stud which is easier to get and prob cheaper?
could i get the brake set up from the DC2R and take the EP3 calipers to use with them?
The EP3 knuckle assembly won't fit onto your EJ8 due to it being MacPherson strut and the EJ8 is double wishbone.
I know for sure the EP3 rear calipers will fit on the DC2R trailing arms but you will need to mount the left caliper on the right side and vice versa. This is so the ebrake cable can work properly. I'm not too sure about the front calipers.
