Guys i need help, if i put a b16a2 motor into my eg civic hatch would it need some custom work or mounts being done to it inorder for it 2 fit perfectly ?
Ash
Ash
search the DIY section.
there is a DIY on putting a B18C in an EG wich is similar if not the same.
you will need the following if this engine came out of an Ek4
DC2 driver side bracket
DC2 passenger side bracket
DC2 rear bracket
you can using your existing engine mounts
Obd1 wiring loom
DC2 ps pump
obd1 Dizzy
obd1 alterantor
what is needed if u have whole ek4 front cut? just brackets or mounts?
