Hey,
my SRS light has popped up lately and ive checked the fuse. the fuse is fine and i replaced it anyway. its still there and wont go away.
any thoughts on how to turn it off?
Hey,
I do not know if this applies to the teg's , but this is an factory problem for EK's , have a go at this DIY and see if it helps .
http://www.ozhonda.com/forum/showthread.php?t=69095
If that doesnt work, I would be looking at your clock-spring
make sure the SRS plug is still connected.
otherwise, follow the DIY section
before you do all that remember to disconnect your battery and let it sit for 3-5 minutes before disconnecting or reconnecting the srs plug
last thing you want is a non-secure airbag punching a hole in your face
