please help adjusting my headlights on my eg4 civic im blind at night:(
or point me in the right directon thanks
park infront of a garage/wall with your lights on (at night)
Jump out , pop your bonnet and grab a medium sized PHILLIPS HEAD screwdriver. Look above both headlights and you will see a guide hole and a funny looking "winder" mechanism. Looks like a piecutter cog. Place your screwdriver gently against this , and turn to raise or lower the beam slowly. Dont rush.
Make sure the drivers side is slightly lower than the left.
Hey bennjamin does this method go with all cars??
most cars have the same type of adjuster and same principle The Jazz, for example has the same adjuster in a different location.It also has a 10mm bolt end to use a spanner or socket
thanks!
