POWERBAND Catalogue - Cammed Motors Specs + DYNO Graph Mandatory
		As per title and my post here:
http://www.ozhonda.com/forum/showpos...3&postcount=53
DO NOT POST IF YOU HAVE NO DYNOGRAPH TO GO WITH IT!!!
Bits below highlighted in Red are mandatory prior to posting.
Purpose of this thread is to give NA modders a better insight into tackling the head as it is where you'd go first... no-one here should be concerned with numbers but the sole purpose is POWERBAND. Peak hp at a cetain powerband is pointless as that depends on your tuner and dyno... the curve tells all!!
Must be in shootout mode or SAE corrected + 4th gear preferablt with rpm at the x-axis instead of km/h
Stock heads are welcome especially if you have dialled camgears.
Engine -
Displacement -
Bore -
Stroke -
CR -
Camshaft -
Camgear Settings -
VTEC X-Over -
Gearbox -
I/H/E -
ECU -
Please do not molest this thread with stupid questions, it should be a referable thread for the others.. can the n00bs please read all of this first and not bombard this with crap:
http://www.ek9.org/forum/resource-ar...s-engines.html
***EDIT***
Please also include VTEC x-over if you know it :)
keep em coming!!!
CATALOGUE - Post #s
OEM B16A2 - #42
OEM B16A2/B20B - #
JDM B18C - #250
JDM B18C - #396
OEM B18C2 - #404
OEM ITR B18C7 - #3
OEM ITR B18C7 - #51
OEM ITR B18C7 - #362
OEM ITR B20Vtec - #81
OEM B20Vtec - #11
Buddy Club Spec III+ B16A2 - #84
Buddy Club Spec III+ B16A2 - #239
Buddy Club Spec III+ B18C7 - #316
Buddy Club Spec III+ B18C7 - #392
Buddy Club Spec III+ B20Vtec - #81
Rocket M22x B20Vtec - #26
Rocket M22x B20? Block / B18c7 Head - #289
Skunk2 Pro1 B16A2 - #6
Skunk2 Pro3 B18C7 - #368
Toda Spec C B16A2 - #297
Toda Spec C B18C7 - #16
Toda Spec C B18C7 (Turbo) - #17
Toda Spec D Int, C2 Exh B18C2 Block / B16A2 Head - #18
Toda Spec D Int, C2 Exh B18C7 Block / B18C2 P72 Head - #275
OEM H22A (Type S) - #359
JDM K20A - #245
OEM K20A2 - #28
OEM K24A3 - #2
OEM K24A3 - #14
OEM K24A3 - #39
Buddy Club Spec 3 JDM K20A - #57
Toda Spec C K20A2 - #338
Toda Spec F K20A2 - #15
Toda Spec ? K20A2 - #318
