DVD Rom Replacement for Sat Nav...
Hi All,
Here I go again... Just after your opinions if you can replace the standard DVD ROM with a single din DVD player/monitor? In other words what I am trying to do is still have pure navigation on the standard sat nav, but if I don't want navigation, I can use the single din dvd player to watch movies etc? Obviously the movies will play from the single DIN monitor and the standard sat nav will have to be on radio or air con.
I guess the output from the single din dvd player monitor would have to connect to the sat nav. If I want navigation, I can insert the map dvd disc. If I want movies, I can insert a dvd.
It might be possible because you can still run the air con, radio etc without the dvd maps.
Just trying to get the most out of the limited space!
Thanks!
Regards,
Eco..
