Ahh, I see.
Ahh, I see.
Issue: Drivers side not opening through immobiliser
Resolution: Covered under warranty, drivers side central locking system replaced. Done 50,000kms, 2005 model Euro.
Also, When i went to them with the problem, they told me there was a recall on my model euros since the headlight was sweating/condensation inside. And got that replaced and fixed by them aswell.
50,000 klm's
1) Got my battery replaced, found to be faulty.
2) 1 hinge strap for right hand passenger door
problem- manual gear lever vibrates during 2k rpm range.
result- dealer changed the plastic block under warranty, as it was somehow worn and the engine vibration amplified the sideways play in the stick.
note- dealer found previous owner damaged front bumper mounting (some kind of light impact) and initially refused to honor all warranty, but came around after a stern talking to. http://www.ozhonda.com/forum/images/smilies/tongue.gif
:p
New Steering Rack.......squeeling when car stationary
Ekk, my Euro is a week old and i have some issues that need looking at..
1) The sunroof seal (outside) looks like it's 10 years old and is faded and peeling in some places.
2) The clutch delivers a creaking sensation when pressed and released.
3) The wiper blades are horribly noisey when used.
Now i have had tiniting done today and cannot open the windows for a few days or so but based on what i have read here it sounds like they will scratch. What do i need to do to prevent this?
Regarding tint you have to wait till they scratch then tell them you want window trims replaced with felt....just let them know that you have been to this forum anf you knoe that it is a common problem, you shouldn't have any issues with them replacing them if you arm yourself with this information from here....do a search on tint scratching very useful.
Sunroof has issues with seal aswell......can get squeeky, if old looking and peeling ask for replacement, once they replace it keep it lubed yourself using silicon grease or good quality marine grease, hope this helps.
As for the wiper blades and noise ask to get them replaced as your car is fairly new shouldn't be doing this from new.
good luck
Front Passenger side lock not opening, resolution they changed the lock mechanism on that door.
Whoop sound from air con, they "eventually" changed the Tx valve.
Audio Head unit replaced under warranty at 70,000klms. Error message then cd player failed to work.
LXRY,you've had more than your fair share of warranty claims.:thumbdwn:
I have had the sunroof completley replaced and the wiper blades replaced = all good here but i'm now rattles popping up already (1100kms). There is an annoying one on the RHS up top between the airbag cover (A Pillar) and roof lining that the dealer is refusing to acknowledge. The LHS does is sometimes also. Sometimes i hear the dash creak too.
They also dismissed the clutch pedal whereas it feels like it's scraping something when you press it in/out. They reckon it's normal but sometimes it seems intermittent (any ideas?). The brake pedal feels a little loose (sloppy) too.
Despite the dealer telling me the Honda a fantastic built car and that i will never have issues i am starting to beleive i made the wrong choice.
