Correction,
'92 - '95 model
If your goin to buy one,get the ecu specific to your car.
Also get it diagnosed professionally before handing over any cash.
Correction,
'92 - '95 model
well that may take a few weeks as i work 6+ days a wk while my manager is on hols, the engine light only comes on when its cold but after restarting the car when after it turns on it doesnt come on again until the cars cold again. will it hurt the car if i continue driving it till i have some time off?
will 1 from any b16a2 do?
Sorry,I meant an ecu specific to your engine,ie OBD1 AUDM? B16A,but its gonna be hard to find anything other than a crx ecu,no such thing as an aussie b16a OBD1 civic.
Wait for some cleverer types to come on & see if u can keep driving it,but if its spitting codes that dont exist,then who knows the extent to which it is working correctly.
Just take it down the nearest Honda dealer,they will most likely have a workin ecu on hand & can quickly do a swap to see what the prob really is before buying ecu's.
Try posting a wanted to borrow,gotta be some OBD1 ecu's cruising nearby somewhere.
what cars did have the b16a2?
Only yours for AUDM OBD1.
U could prob run a JDM ecu,but its not optimised for aussie fuel & compression ratios.Maybe one of the tuner boyz on here could correct me if it will still run your motor ok.
Aftermarket ecu is the other option,but u really got proper diagnosis before troubling yourself with all this.
in my EK that 3 connector is dangling and not connected to anything, is that good or bad???? :S
thats goodQuote:
Originally Posted by nine_7_six
JDM ECU will run the AUDM B16A2,
in stock form you will have a ELD problem which you could ignore
code 52 could be a result of a interal fault in the ECU. usually if you get a weird code that is not in the list, you have ECU issues.
if you can try another ECU.
i was just wondering.. is it possible to reset the ecu by removing the negative terminal on the battery and steping on the brakes untill.. u run outa power ?????
Read around a bit please. To reset the ECU just pull the ECU fuse out or remove the negative terminal of the battery for a few mins and put it back. Nothing to do with the brakes.Quote:
Originally Posted by khOa`
does anyone know where to find this wire on a 4th gen prelude
i look under the glove box but cant find it
thanks 4 your help!!!
ive checked my ecu and i got code 21 - vtec spool valve...
my vtec wont engage... i already reset the ecu and still nothing...
i had another ecu installed to test and vtec was working...
is there anything i can do with my ecu??? i ws told 2 replace it... wat r my options
