rear most liekly, depends how much camber u run n how low the car is and tire size
front, no chance
front, no chance
front will fit, but you need roll, you ALWAYS need to rolll your front guards if you plan on lowering you car.
Those sizes will fit if you run 225's all round
Sorry in bringing an old thread back up, but just wondering if at 17x9 +45mm RPF1 will fit for the front and rear?
If it doesn't what would i need to do to get it to fit?
Thanks Guys
You will need a roll of the fenders F&R if you wish to run a chunky tyre all round.
RPF1 17x9 +45 with a 255/40 all round is a popular track setup in the SCCA / USA.
GUYSSSSSSSSSSSSSSSSSSSSSs
17x8/ 17x9 +33 RIMS WILL THEY FIT ON A S2000?? without running camber ?!?! and what tyres!
THANKSSS DUDES
Thanks, i was thinking 235/45 for front and 255/40 for rear?
So your suggestion will be a 255/40 all around for the Rims that Ill be getting?
might as well ask a noob question would 16x8 +40 look to small for a s2k? So slightly wider then stock wheels?
depends on the style of the wheel being a 16"
there is a gallery on S2KI.com with 16" wheels. some look good. some look gay balls
sam
they will fit on the s2k but u will need to roll front and rear guards and relocate the rear tab.
now to answer ur question of camber, it depends wot type of look ur going for?
full tyres? (F:225/45 and R:255/40) or
ap2 spec tyres? (F: 215/45 and R: 245/40) or
stretched ish? (F:205/45 and R:235/40)
dont quote me on this, but stretchedish look will require at least -2.5 to 3*camber on the rears and about say -1.5 to 2* on the front
and obviously full tyres would need a bit more camber.
i'd go for ap2 spec tyres lol
im running -3* camber all round but 0 toe, toe is the main factor that kills tyre life yoo
hey guys got a set of bbs lm 17x8 40 and 17x9 42. what tire sizes should i put on them? i dont mind rolling the guards if i have to. i was thinking 225/45r17 front and 255/40r17 rear but im not sure if they will fit. helps?
