I have the Hardrace camber kit at the rear and one side maxed out at -2.1 degrees. :/
yeh raise it up man see if it helps
I have a strong feeling the jax alignment machine was ****ed..Those numbers just don't sound right.
I am running dc5 suspension however luke...Do you think that the dc5 coilovers have a different geometry?
Because according to the jax machine I am getting 2.3degs LH and 2.78degs RH camber...That definetely sounds off. OR...the coilovers somehow changed the geometry alot.
dc5 coilovers not oem, I have a strong feeling it is that. Put the car onto my mechanics wheel alignment gear and same results.
luke see if the below link can be of any help~ :D
http://www.hondaoriginalparts.com/ho...&block_03=9511
