I see your going down that route as well, buying Georges K24?
I'll be careful with this. I believe JDM facelift uses D2S bulb for their low beam hids. I think H1 are used by UKDM spec and also uses a different headlight housing even though both are projectors.
http://i1080.photobucket.com/albums/...RHeadLight.jpg
Facelift Headlight Unit - No.1
HB3 Light Bulb - No. 7
D2S Type HID Light Bulb - No. 8
Factory HB3 Light Bulbs Holder - No. 10
Headlight Burner Cover - No. 12
Headlight Burner Seal - No. 14
See part number from this japanese epc website. http://honda.epc-data.com/civic/aba-...electric/7586/
No you can't reuse anything from your prefacelift. Different housing, different bulbs, and different wiring. Johno has done this before and wiring needs to be reconfiged.
If you're getting from Phillip, you must get the whole kit. It is completely useless to just buy the housing.
Another warning, do not buy projectors from hondaoriginalparts.com because their housing is only for UKDM which does not use HID. If you buy them you have to buy an aftermarket h1 hid kit to work with it. I have a friend who gone through this step.
So in conclusion you got three options:
1.) Buy the full headlight unit including ballast and bulbs from Phillip
2.) Buy brand new OEM projectors for UKDM spec and install aftermarket H1 HID kit
3.) Buy projector replicas from US and install aftermarket HID kit.
A fellow ep3 owner has asked me about the hid bulb for prefacelift and thought this might help some other ep3 owners.
H4's are halogens bulbs which are used by the UKDM spec.
The correct size is D2R for prefacelift and do not come cheap.
Please see the follwing diagram below:
http://i1080.photobucket.com/albums/...-capture-3.png
Part Number: 33116S0AJ11
For reference please see this link:
http://honda.epc-data.com/civic/la-e...electric/7584/
I think there are some D2R bulbs on ebay for around $70 a globe.
But I'll try to find out if there's any where else.
