I wouldn't read too much into UTQC's. My old RE050's had a rating of 140 yet they lasted me 45k km. (a lot of highway driving though).
cant agree more with you guys there about the tread wear rating, good to see there are ppl on this forum judging tyre life based on past experiences rather than blindly believe the TRW printed on the tyrewalls.
I'll post up pics of a set of RE711 I bought some 5 years back that has done over 90,000kms and yet has some 10,000kms left in them. Dont forget when the tyres are gripping well there is no abnormal wear, a sliding rock hard tyre wears fast. Not surprised about the ES100, after 2-3 years even with over 50% tread depth they become rock hard.
hmm. Thanks for the advice, starting to question the treadwear ratings thats for sure. I have been very unimpressed with how my T1r's have worn - the outside edge is almost bald, yet there is a solid ~3mm in the middle and inner edge.
If it was dodgy pressure, they should have worn more on both the outside and inside edge (assuming pressure was too low) or in the middle (if it was too high), so I can only assume I need to drive a little more sedately.
that sort of wear usual.
i would check the wheel align settings, may be you have positive camber on that wheel, and possibly with excessive toe on top of that.
yeah i had some issues with the business i bought them from, initially. one side on the front was wearing remarkably more quickly than the other.
they blamed this on the fact that roundabouts are always entered the same way and this can cause excess wear.
now, thanks to the intial wear pattern, theyve continued to wear unevenly and 2 are now due for replacement. bah
between 10k - 15k (don't keep a record of these things)
I never launch 1st gear, but i chirp 2nd a lot of the time when i do drive hard.
maybe 50% hard driving and 50% normal driving. again, i never keep an eye on these things, I just enjoy.
btw, my tire pressure is always on 38psi, front & rear.
cusco zero2 spring rate f8 r6..... front setting 3, rear setting 2
