Got my kit for about $70 when I was in HK. I think from Honda Australia you'll be looking around $100+
Bought from supergt
I think they're pretty cheap in the US as well.
http://www.jhpusa.com/store/pc/viewP...idproduct=4450
damn thats more than i thought... i looked on ebay and found this: http://www.ebay.com.au/itm/OEM-Genui...ht_2667wt_1037
but not sure if it will fit the jdm k20a :S ...
That ebay ad looks like it's ONLY the gasket. It doesn't look like it includes the spark plugs seals and polished valve cover washer grommets.
yeah just thought maybe it'll be cheaper if i get that , then get the spark plug seals at the dealer, and do i really need the washer grommets?
Will i be able to run 17x8 with +29 offset without running camber? Anyone running similar or less offset?
A mate of mine runs 17x8.5 +31 advan rg II`s, with 225/45/17`s all round, unrolled guards, stock height and camber. He has very minimal rubbing in the rear when it is loaded up.
http://www.1010tires.com/WheelOffsetCalculator.asp
The 17x8 +29, will retract by 4mm. So you`ll be fine with either 215/45`s or 225/45`s at stock height and camber. If you find it rubs anywhere then roll the guards if necessary.
hey sydney ep3 owners, just wondering what insurance company are you guys with? how much are you paying,
just car's and nrma are the only ones that insure imports?
im with nrma but am not happy with them as fire and theft cover is only up to 10k cover. Fairly certain its the same with just cars
looks like it doesnt insure people whose under 25, was planning to put my dads name and mine,
