What height are you planning to run?
IMO, running aftermarket wheels with stock height looks a tad strange, to me at least =P
Phil Lee mentioned in this thread:
http://www.ozhonda.com/forum/showthr...el-Setup-Guide
... that from his experience 17x8 +38 is the most aggressive you can run without any poke or camber.
Note that what tyres you use will have a big effect.
Im running 17x8 +35 on my EP with 30mm lowering on 215/45r17 and this required the rear guards being rolled, and I'm running pretty aggressive camber (-2.5 up front). The camber is not necessary, but since I have passengers every now and then, I'd prefer to clear the guards completely. Better safe than scrubby! .. Ugh.
If you plan to run the stock 205/45r17 tyres, you'll get a little stretch, which might help with any rubbing when going over bumpy surfaces.
Back to the question.
17x8 +29 on stock height. Yes it will fit when your car is stationary, but it is very likely to rub, especially the rears once you get moving.
Might be wise to account for the possibility of rear passengers too :)
What wheels are you looking at getting bro?
