clutch pedal doesnt seem spring up all of a sudden randomly tonight any thoughts clutch cylnder seal gone?
Alright, after owing this thing for almost a week now, I am falling in love with it more and more every time I drive it. I keep saying it, but what a fantastic car.
Couple of questions:
Does anyone know the paint code for the silver interior bits? I'm pulling it all apart shortly to install my system and would like to have it painted whilst its out. Looking to get a few decent coats of clear over the colour so any scratches won't show up unless they are really deep.
Does anyone have the exact specs of what a factory wheel alignment should look like? i.e.: Camber, Castor etc etc. My steering wheel sits a poofteenth off centre and I would like to have it aligned correctly, given most tyre shops locally will not have seen one of these before, I'd prefer to have a starting point to give them to save them spending half the day using my car as a guinea pig for their trial and errors.
can't help with the paint code for the interior silver bits but u can take them to your painter to ask them to match the colour.
with factory wheel alignment, they only give a range of measurement which is useless. you can't change camber anyway. they can change the toe to fix that off centre issue. the chassis for EP3 and DC5 is very similar so maybe you can ask the shop to try using the DC5 setting as a base.
Yeah stock has jack all adjustability.
I'd imagine setting the fronts 0 toe may help.
Stock EP3 appears to have (correct if I'm wrong Phil) pretty close if not on 0 camber up front and some negative camber up back.
what are some nice rims light weight suggestions?
I did some research and the stock rims are around 10kg.
Volk TE37 around 6.8kg. Is it a big different? is it worth 3k?
Too easy, thanks for the replies guys.
Almost got divorced this morning when I explained that I was considering starting my stereo install this weekend . . . stupid mothers day! I guess that will have to wait another week.
have anyone considered XXR 521's? planning on getting them though will it be a hassle to get a good fitment? on 17's
