Sydney, Liverpool metro
I've got a few quotes but it seemed way toooo much just to assemble everything together.. Maybe the fact because its a "B20VTEC rah rah rah"
Its usually about 1-2k to machine and assemble.
I would be putting bearings and arp bolts in it. And probably rings if i wanted to just slap it together.
I would be putting in 13:1 compression pistons new rods and what's mentioned above if I wanted to just slap it together.
I'll be replacing rings, bearings, machine the block..
So anyone knows who i can contact in sydney? Preferably a workshop with a license, no bodgy backyard shit
edit first post; I do have arp studs and rod bolts to go with it
needs more high comp pistons
I have a b18b stroked to around 2L with darton sleeves ... Looking to rebuild it was thinking of going down the b18c 87.4 mm crank shaft as opposed to the 89 mm ls crank .... What is your thought on this change people ... I know id loss low down torque... It will run e85 and m24xx cams on supatech valves and springs
Give jdmyard a call we do a lot of our own engine builds including my engine
A lot of good information in this thread. Shame to see that it was buried.
Where's bot
He might want this for tank buster
Love the tags for this thread
