Ahahaha oh man you got some troubles run, run away quick!!! Regular pussy is not worth going through that, plus how will you be able to mod your car?
That petrol price is only for normal unleaded 95 try more like $1.47-$1.57 for 98
I get 420km then light turns on. i fill up around 40-43L ... so im guessing it is using 10L/100km. Completely stock car... but i like hitting vtec :)
I'm getting 500 odd.
Few mods. Most I got was 520.
And who doesn't love getting their vtec on!
thats pretty weird, could it be the o2 sensor failing? ive read people having the same issues and the fix was was replacing the o2 sensor.
but from your build, you changed the headers right, did you tune the ecu? ive heard you have to if you change the headers but i can be very wrong about it
oh okay then, that puts the tune out of the equation. but hope to see some results when you get all the parts you need and get them on haha,
but a lot of the issues ive read in the european forums, relating to bad fuel all seem to some how relate back to the primary or secondary o2 sensor,and need replacing or something but then again their ep3 is different in the uk then the jdm ones we get here and considering we have k20a while uk have k20a2 but all the parts are still universal
Running no secondary o2 at the moment as it grounding out on the chassis due to unrelated problems.
I am getting flightly worse economy but not 350kms O.o
Also, what engine oil are you running?
Could be to do with the thickness of it, though I'm not sure if it effects mileage THAT much.
