It depends how you want the LED turned on. You can either wire it to your tail light's parker or brake wire.
Thanks for replying Atjo. I pretty much want it to be exactly like my rear lights, like when i turn on my headlights i want it to turn on and when i brake it goes brighter, etc. How would the pathing of the wires go all the way up to my tail lights though?
Not sure that's possible man, You'd need to run it off the brake lights, and have the two positives running in and one negative running out to a ground.
Dam you serious .. so at night you cant see it unless i push on the brake? That's a bit gay lol. I remember seeing a video and this guy pulled it off but i cant find it.
Just went jdmyard to witness a fd getting a k24 conversion... is it anybody off here?
I think this is what im talking about if im not mistaken ..
http://www.youtube.com/watch?v=glGES...eature=related
Like DuffyFD said, it might not possible but I could be wrong. The only way to do is test it. You don't need to wire the negative to the ground. You can wire it to the negative cable from the brake lights. The easiest path would be from underneath the bumper go up to the brake light.
Yo Duffy if your on here, we are heading to Krispy kremes
