Yeh dam. Imagine the mods you could do with that amount of money.
anyone got the headlight connectors diagram? I still got the original factory hid headlights and trying to install them. Took them to a mechanic but they couldnt put them in cause the plug has been cut off
Can I buy the original plug somewhere? Thanks heaps
I guess something like http://passwordjdm.com/PasswordJDM-H...-P971C320.aspx but for the ep3?
does anyone know why theres a loud knocking noise coming from rear when i over gas a launch in wet causing tires to spin a bit
its been wet and was a steep hill
gassed it a bit too much
next thing, pulling to the side and tires spiinning a bit
but wat worried me was this loud knocking sound from the back
sounded liek rocks hitting the under carriage
anyone else had this happen before?
It's lack of traction and the suspension / driveshaft loading up or something i.e. wheel tramp.
A mate of mine told me back when I had a xr5. More prone in the wet.
Totally normal as it happens too a lot of fwd.
My ep also does it every now and then.
Does any one know where I can get a primary and secondary O2 sensor for cheap for the EP3? the one on amazon is not available to be shipped to Aus for some reason
Have a look at this.. not sure if it's what if it's what you're looking for, and it's used.
easy guy to deal with :)
http://www.ebay.com.au/itm/Civic-Typ...#ht_500wt_1054
Honda?
Are ate ypu using that as a last resort as they charge 3 limbs
Lings Honda based in uk sell parts and they ship to Australia.
And brody is correct, will be pricey.
Think this is the right section..
http://www.hondaoriginalparts.com/ho...&block_03=9726
parts industry is f**ked. Honda must be making an absolute killing. Along with all other makes.
Anyone know how to change the brakelight bulbs (Pre-FL)? Thinking of doing an LED conversion, but theres this red cap covering the socket from inside the boot. It seems pretty solid. :S
