pm me as well~
pm me as well~
there are a lot of civics with the rr kit or mugen kit in taiwan...
1am -5.30am Natio run with my mates evo.
Priceless
Don't think I've sent that many sparks flying everr
is the FD1 front and rear seat can be replaced by FD2 (leather) seat?....saw a wrecking FD2 at gumtree.....i think the rear seat shouldnt be a problem...but the fronts has side airbags,,
I do believe everything is interchangeable. Don't quote me though.
Yes, they should work, but you will have to reset the SRS system.
hey guys if i have an exposed pod filter directly connected to my stock intake pipe would that damage my engine as that means it would be sucking in hot air right next to the engine..?
Would do next to no damage, would not improve performance, if for sound and looks go ahead. Please also note that the air sensor is located on the airbox - you will need piping with the sensor then the air filter.
Anyone know the difference between a Fujita CAI and an Injen CAI in terms of power gains and longevity?
so the last time i spoke to the jdmyard owner in regards to that, he mentioned the following.
fujuta is cheaper in quality and price however not dyno proven..
injen is dyno proven, made form better materials and a little more expensive
Thanks for the heads up ekdez.
In that case will this fit our cars?
http://www.ebay.com/itm/INJEN-CAI-CO...#ht_1020wt_938
Only if you have a manual Baygon.
Btw I'm getting very close to getting some poly LCA bushings after reading all of the 8thgenner's raving about them from the USA.
http://www.8thcivic.com/forums/suspe...m-bushing.html
http://www.8thcivic.com/forums/suspe...l-upgrade.html
these:
http://www.energysuspensionparts.com...prod=16%2E3116
