Did you try to regrease the steering rack?
A lot of this creaking is the actual subframe or chassis around the steering rack.
Incorrectly torqued mounting bolts/ reused bolts for the steering rack can creak and groan , as they are under significant load from the rack and wheels/suspension.
Pretty confident it's the steering rack needing greasing now; just read a thread on clubep3 with the same problem and posted the exact same videos lol. How do you remove the metal ring that holds the rubber boot? Is it re-usable?
Might buy some hose clamps then, same ones they use for holding the intake hose lol That way it'll be easy to loosen aswell, guess i'll just cut off the rings then, hope i don't damage the boot.
But then the ring that holds the boot is metal lol
http://www.freeimagehosting.net/uploads/99d4b8bd75.jpg
Ahhhh, I was imagining you doing something else...
Disregard XD
Hi All,
Needing help here - I've recently started to experience grinding and some rattling on the right side and ocassion ratting directly underneath my seat.
When i first experienced i thought my recaro chair was moving but i soon realised it was the rattling that was occuring.
It occurs on throttle in any gear and it will last for several minutes as im driving and will intermittently go away. When it is in neutral the grinding and rattle goes away. When i REV it in neutral from memory i think it also makes the grinding sound like its being supressed.
RIt has happened for 2 days now and I dont want to cause any more damage. Right now it's at a friends house and I dont want to drive it causing more damage and want to make sure Im looking after it.
I am unsure what to do and want to fix it as soon as possible, any help would be great. Also if anyone could recommend a place to take my beloved car to in Sydney that would be much appreciated.
Yep, greased up the steering rack and the creaking sound is gone now. Took me a while to pry the clamp off tho, held down by zip ties temporarily. Must be the winter and my car has caught a cold lol Thanks guys!
off topic but..
farkk.. changing the clutch in the ep3 is a dam nightmare. haha one of those days where its just one thing after another. should be done tomorrow arvo though along with the new radiator, thanks to Mishimoto:) (fingers crossed).
Havent driven it for a good month or so now.. just want it on the road!!
what clutch did you get?
