Originally Posted by
psykotech
I have an MY13 CU2 6MT which is pinging. For reference I've always filled up with 98 (BP/Shell) from metro service stations that get plenty of traffic.
The car seemed ok for the first 1000km, it became noticeable around the time the 1500km service was done. Nothing was noted during the inspection.
A week after the 1500km service was done I took it in to have it checked, the service manager had a quick listen and told me to mention it when I dropped it in for the 6 month/10,000km service.
During the next two months it became even worse, especially when it was cold. At around 3000-3500rpm it literally sounded like a diesel, so I pretty much avoided driving the car unless absolutely necessary.
Two weeks ago, with just on 2000km on the clock I took it back again, booked in to be checked over on the 5/10. They noted a misfire/ping starting at around 3100rpm. They replaced the plugs, checked the injectors (fine), tested the fuel (fine) and the operation of the knock sensor. They added some injector cleaner and gave it back to me to see how it went. It seemed ok driving home from the dealership, but the next morning it was back to how it was before.
On the 10/10 I took it back in, they had it 3 days so they could test it while hot & cold, apparently were in contact with Honda's technicians most of the time trying different things to fix it. I picked it up on the 12th, was told to run out the remaining fuel (2/3 tank) and then fill with BP. The service manager pretty much admitted that fuel wasn't going to be the cause, since it was fine sometimes. During the time it was in they damaged the centre console and left something loose under the dash, they've said they'll fix it though.
The next day, it was just as bad as it was before it went in. At 3000rpm it sounds like a tractor. They promise no damage is being done, but I'm not convinced.
At this stage I'll play their game, run the fuel out and try a different brand, but I'm fairly certain it'll make no difference.
Does anyone have any advice on how to proceed?
